Hello! I’m trying to extract the boundary of a Filled Region (created under the Annotate tab) and I can’t seem to find any node to do it or any solution online. Ideally as a curve, but anything can help.
Thanks!
Léo.
Try Springs.Collector.ElementSketch
Perfect, thanks a lot!
Hello. I have a question. If I have 10 fill regions. How could you get each of your curves without the need to select one by one?
Tank you. Thanks to your answer I can continue with my line code
