Hello hive mind!
I’m trying to get the value as displayed in two parameters and concatenate them into a string. In the image attached, I wish to use the two values and arrive at 18’ - 0" x 9’ - 0".
I can “see” the value as a text, but the dimension extracted is numeric.
I went about inverting the list, extracting the values, but it’s not a string I can perform operations on.
I feel like I’m going around in circles, and there’s a very simple solution. What’s the best way to go about this?
I do not have the Springs package installed. Best I can do is to advise you to double-click on the node, copy-paste its content in your .dyn and see where does the error occur
@Kulkul Oh Yes! Absolutely!
I had to uninstall Dynamo 2.x as I wasn’t able to run Dynamo 1.3 and it worked. But I do wish to work in 2.x going forward.
What was the fix, and also, how did you get the 0" to show?
