For a project i have a lot of dimensions and change it to a text, like on the picture.
I wand all those replace text to export, it tray it with dynamo, but the only value i get is the real distance.
Is there a other to get this value?
Thank you
Hi Mate,
If it is single-segment dimensions you’re working with, you could use below. If’ you have multi-segment dimensions however, it will be different…dynamo file attached also.
Get dimension Value
Hi Jeremy,
This is precisely what i want.
Thank you very much!
