Hi all, is it possible to extract curves from a tag family? I want to grab the tag and redraw the lines, as detail lines inside Revit.
Which parts of the tag do you want?
Why do you want them (there May be a better way forward but we need the insight into what you are doing).
Hi, thanks for the quick reply, mainly because I have a floorplan and I have already tagged the walls with their wall type. Now in another floorplan I need the wall finishes, and so I was thinking of annotating the walls with wall finishes with the same lines (so I want the lines from the tag, and potentially the text box)
P.S On the left is the tag, and on the right is the wall
