Hello guys,
is there any way to bypass this one?
Basically the idea is to
create an empty sheet
place viewports
get boundingBox of each viewport -> I need Points
This way I can get whole BB with viewport title
I don’t really need to create this sheet with all viewports so that’s why there is a rollback.
But still can’t bypass
.get_BoundingBox(view)
trans = Autodesk.Revit.DB.SubTransaction(doc)
trans.Start()
try:
if Viewport.CanAddViewToSheet(doc,sheet.Id,v.Id):
vp = Viewport.Create(doc,sheet.Id,v.Id,l.ToXyz())
bounding = vp.get_BoundingBox(vp)
minPoints.append(bounding.Min.ToPoint())
maxPoints.append(bounding.Max.ToPoint())
except Exception, e:
outList.append(e.message)
trans.RollBack()
TransactionManager.Instance.ForceCloseTransaction()
I can get points using:
vp.GetBoxOutline().MinimumPoint.ToPoint()
but these points don’t take into account viewport title ;/
Full Code
clr.AddReference("RevitAPI")
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
titleBlock = UnwrapElement(IN[1])
views = tolist(UnwrapElement(IN[2]))
locs = IN[3]
outList = []
minPoints = []
maxPoints = []
if IN[0]:
for v in views:
trans.Start()
try:
vp = Viewport.Create(doc,sheet.Id,v.Id,locs.ToXyz())
bounding = vp.get_BoundingBox(None)
trans.RollBack()
OUT = (minPoints,maxPoints)
OUT = "Set Run to True"
GetBoxOutline() & GetLabelOutline() methods did the trick (without BoundingBox).
Still, it would be nice to know how to do this using BB
