Hey
I haven’t made anything yet, because i not sure how to start.
I want to make a script where i can read the angels from center window or door, to it hit an object. And it shall be measuring from the center, both horisontal and vertical. I think something with a plane, but then i’m lost. Hope you people have som ideas.
That worked, with center point.
Okay
If we make a plane in the Z-vector from that point, what angle do you want?
If we make a line on that plane it will allways intersect with the Window
Also try Element.GetLocation on the Windows and it will return a point (The insertion point in Revit)
Line.Direction will give you a vector along a line… might be useful…
I want to find the angle X and Y from the picture. I’m just not sure on how, but i will try all your suggestions tomorrow.
I preferred it when you were looking for angels
This kind of direction might help? Dynamo - Push room name data to ceiling components
Mark
Hi
Have you ever solved this script? I’m trying to make something similar and struggle at the part of getting the angles… I’m trying using ray-tracing to do that
