Geometry.Intersection: Feature or Bug;
If I generate curves by intersecting planes and geometry (see image) then the curve created at Z=0 (coincident with the volume bottom plane) seems to have different parameters than those that follow. Can someone please confirm?
Thanks, Peter
Swap the inputs in Geometry.Intersect
Ok - that’s a solution, thanks. Any idea why that should make a difference?
I suppose the orientation of the geometry has priority over the entity
The normal of the bottom surface of the solid is opposite and the surface obtained as a result of intersecting it probably inherits that orientation.
Just checked and you’re right. This means that for some reason the bottom surface has priority over the side surfaces. If I generate the curves by intersecting just the sides and the planes then the points do line up - regardless of how they are connected to Geometry.Intersect.
As an aside, I also see that the direction of the curves are not always consistent - I get odd results using offset - see image.
Maybe this is related to this bug: https://github.com/DynamoDS/Dynamo/issues/5477
Needs a direction point…which I’ve requested! In the meantime SpringNodes has an offset with a direction point.
