Hi, everyone
Regarding the Geometry.Intersect utilized, I got stock because the Filter number is kind wrong.
Thanks for your help and discussion
Cheers,
SHUOTAO
Filter test.rvt (3.3 MB)Fliter.dyn (12.3 KB)
Hi, everyone
Cheers,
SHUOTAO
Filter test.rvt (3.3 MB)if the family is inside the room you needed to filter, you can use familyinstance.room node
This is my question part, I dont understand why the amounts would be changed.
Sorry again, as my study knowledge could not switch the part like your shown.
Can you give me the method to “1” -> “Auto”
Thanks again!
SHUOTAO
you can click on the “1” , to change it to auto
by the way is not a 1, is just a icon
Extending the idea, I would like to add the other box in the same concept.
However, the same result shown and could not catch the information with my new object. What is this problem?
ShuoTaoFilter test.rvt (3.4 MB)
Fliter.dyn (16.7 KB)
Looks like you may be using Dynamo 1.x. Auto lacing isn’t available until 2.x, so you’ll need to upgrade if you want to make use of that feature.
