Generic Annotation Linked Element Coordinate
I have some lines, and some generic annotations coming from a linked model.
I’ve collected the elements via BIMorph Nodes, but when I get the location the coordinate of the generic annotation is not even close.
The PBP/IO X & Y values are identical.
I’m trying to find the generic annotation that sits within the surface of a closed loop of lines to be able to identify the zone because there is no filled region or room, so once I have the correct position of the generic annotation, I’ll find which loop/surface the point sits in, then I can match the surface/loop to the zone.
All the different nodes I’ve tried report the same coordinate for the generic annotation:
In Dynamo:
In Revit:
In the host model:
Hi there. As the host model and link may have different internal origin, PBP or survey point location, there could be such an issues.
You can try to check the link transform of desired link instance and then translate the point by obtained coordinate system.
Here is an example in Python, taking into account the transformation of the RevitLinkInstance as @Andriy specified.
The code must be adapted to your type of annotation
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
out = []
lnk_instance : DB.RevitLinkInstance = UnwrapElement(IN[0])
tf = lnk_instance.GetTotalTransform()
lnk_doc = lnk_instance.GetLinkDocument()
lst_tags = FilteredElementCollector(lnk_doc).OfCategory(BuiltInCategory.OST_ParkingTags).WhereElementIsNotElementType().ToList()
for t in lst_tags:
    t : DB.IndependentTag
    lnk_view = lnk_doc.GetElement(t.OwnerViewId)
    if hasattr(lnk_view, "GenLevel"):
        z = lnk_view.GenLevel.ProjectElevation
        pt = XYZ(t.TagHeadPosition.X, t.TagHeadPosition.Y, z)
        pt = tf.OfPoint(pt)
        out.append(pt.ToPoint())
OUT = out
You need to use LinkElement.Location node. Using Element.GetLocation node works with Bimorph LinkElement’s but it will only return the location relative to Revit’s file centre, ignoring any transform your PBP applies, which is why its so far away. Whenever you use LinkElement’s always use nodes from its library first and Dynamo Element nodes (or third-party package nodes) second to get consistent results.
