Hi there,
I tested the Generative Design studies, and it looks promising.
I adapted the script, so the grid does not align the internal origin, but an element you can choose.
Unfortunately I can only select one type of element.
Are there scripts where you select several elements of different size, and start iterate the combinations?
Very likely it will be similar to a “plate cutting optimization” script.
Please find it attached.
Grid Object Placement aangepast 02.dyn (351.6 KB)
Kind regards,
Willem
