Hey, there’s nothing obvious that i can see that would be causing your issue… perhaps it might help if you expand the name parameter that you are setting? is there a reason that you’re setting the phase for the first view you create but not the duplicated ones?
Not Really, By Default, Duplicated Views from a View Automatically pics the Phase assigned to the parent view where they were duplicated from.
Right now the only way to have a New Level and not rename is to Save, Close Dynamo/Dynamo Player and then Re Run The Script.
oh right, sorry i thought you’d said that didn’t help… can you try adding a Transaction End node at the end of your graph?
