- Node “Elements in the Room”: You can find the pipes in the room? 2) Pipe: you can split them by type Thanks for collaboration Floor heating 1) Node “Elements in the Room”: You can find the pipes in the room? 2) Pipe: you can split them by type
Node “Elements in the Room” gives error:
Attribute error: “Location Curve” object as no attribute “Point “
It means taking the curves in the pipes?
