Flipped Cross Sections
When constructing a bridge model I imported a curve from Revit and set the cross section to repeat at points along the curve, then to loft a solid between the cross sections.
However the cross sections at points seem to have flipped upside down.
Could anyone tell me why this has happened?
Hi @MBaxyy ,
I assume you used coordinatesystematparameter then geometry.Transfrom ? This happens when the curve goes from convex to concave:
You can tackle the issue by being more specific when creating the coordinate system, like this:
Much appreciated thank you!
