Sa_60
1
I’d like to ask if someone has encountered a node that performs a function based on the following method from the Revit API?
Railing Methods - Flip Method - Flips the railing.
https://www.revitapidocs.com/2020/ad8cbb52-9732-6aaf-1187-1731f6116e81.htm
Cheers
Hello @Sa_60,
You can use a little Python to do this, as follows
import sys
clr.AddReference('RevitAPI')
railing = IN[0]
if not isinstance(railing,list):
railing = [railing]
results = []
for rail in railing:
try:
unwrappedRail = UnwrapElement(rail)
unwrappedRail.Flip()
results.append(unwrappedRail)
except Exception, ex:
results.append(str(ex))
OUT = results
Sa_60-RailingFlip.dyn (4.1 KB)
Sa_60
3
Hello @solamour ,
Please excuse me for a the delayed reply.
This script definitely does the job for me. Its exactly what I needed.
Thank you for the response and the effort.
Regards
No worries - I’m just glad it solves your problem!
