Hi All,
is there maybe some way with Dynamo to define when will Revit use flange, and when not?
In pipe routing preferences there is possibility to enable flanges for certain sizes, but then Revit uses them on everything. If they are disabled, and you try to put them manually they disappear if you modify something down the route.
To be more precise I want that Revit uses only flanges on Valves, and not on other things.
Is there any way to do it, or literally impossible?
Best regards, Branimir
