I am fairly new to dynamo and am trying to duplicate a script I got and am having trouble with typing the script in a code block, I did a little research and seems to Dynamo 2, they updated the flatten command and I can’t figure out how to revise the scripting in order for it to operate properly. I would appreciate any help, tahnks!!!
I forgot to mention that I get the following warning; “Warning: List.Flatten expects argument type(s) (var…, int), but was called with (var, var).”
Try changing DSCore.List.Flatten(Walls.Geometry());
to DSCore.List.Flatten(Walls.Geometry(),-1);
Thanks for the fast reply, as requested please see attached dyn file.
Thanks,
Ben
HVAC_ Fire Dampers_Placing Dampers.dyn (67.5 KB)
Thanks for the fast reply. I made the change as suggested and now am getting a new warning; "Warning: Internal error, please report: Dereferencing a non-pointer.” I responded to the first post and uploaded the dyn file.
Thanks,
Ben
Hi @ben_janik
Try this file HVAC_ Fire Dampers_Placing Dampers(For Ben).dyn (66.6 KB) I have fixed all the error’s now.
Just FYI, Dynamo will give you the inputs and types for the method as you type it.
Thanks for all the help, I’ll have to try to figure out why I can’t get it to place dampers
Thanks for that idea, will help in learning writing script inside of the code block if I can learn it
