# Find nodes and packages in use in a graph
**URL:** <https://forum.dynamobim.com/t/find-nodes-and-packages-in-use-in-a-graph/16367>\
**Category:** Share\
**Tags:** xml\
**Created:** [November 9, 2017, 9:05pm UTC](https://forum.dynamobim.com/t/find-nodes-and-packages-in-use-in-a-graph/16367 "2017-11-09T21:05:10Z")\
**Showing post:** 26
**Author:** ![Ewan\_Opie](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/ewan_opie/32/77070_2.png) [@Ewan\_Opie](https://forum.dynamobim.com/u/Ewan_Opie)\
**Post date:** [November 15, 2017, 2:26am UTC](https://forum.dynamobim.com/t/find-nodes-and-packages-in-use-in-a-graph/16367/26 "2017-11-15T02:26:22Z")
Hi All,
@awilliams informed me of a CSV export error, I believe this is now fixed
_(Null Values being passed)._
I have removed the last download link and here is the new one:
[Sastrugi - Audit DYN File.dyf](https://forum.dynamobim.com/uploads/short-url/f6IxNerNZxHlWOVUaSr2t9wh9R0.dyf) (251.4 KB)
Also, I have investigated integrating a similar search function to the “What-the-Node” in Rhythm. This got a tad intense, so I have adjusted the Audit node to tell users when a node’s package isn’t found and suggests using the Rhythm node separately.
@Steven I am glad that it functions on your PC. This node was written to process .DYN files, so feeding .DYF file will cause errors.
@jacob.small and @Nick_Boyts The CSV export could be used for the workflows you describe, let me know how you go!
_[View the full topic](https://forum.dynamobim.com/t/find-nodes-and-packages-in-use-in-a-graph/16367)._
