Hi. I am very new to Dynamo and have a probably very simple question.
All my families in the project are Generic Models category.
All instances have a parameter Called “Tag” which stores strings like these: AL-01 or NIR-09 or CL-23
I want to read all these values and write the integer part and “-” into another parameter called " Tag Abbreviation"
for example, in Tag abbreviation parameter I like to have: 01 or -09 or -23
I have made the first part of the dynamo network but still have problem in splitting /filtering the values.
I would appreciate your help
With some modification to create something like this
I have the Tag values and I want to fill out the Tag Abbreviation values for all instances.
Hi @vhematiandehkordi,
You can use String.Remove to delete the first two characters.
Thank you. this is very close to what I need.
The only problem is that sometimes there are more than 2 characters before the " - "
Is there any way to remove all the characters before the " - " no matter how many there are?
You can do it like this :
Thank you so much. You are Awesome. Saved me a huge amount of time and frustration.
You’re welcome.
Please mark the post as a solution for similar researchs in the future.
