Hello, I have one more question from my previous topic, how do I separate two different dimension categories while keeping the values as numbers, let’s say I have dimensions that measure building distance to the boundary and then I have dimensions measuring interior of the building?
Maybe you can filter more than 5000 values or dimension types.
This would only be the part of the solution. It should be more complex, for instance, filter values by prefix or something like that.
Use those 2 nodes from GeniusLoci
I got this pack, yet not sure how to use it in my case.
It will return the reference elements, you can use the category of those to filter the dimensions that are “attach” to the element you are after
I’m not gonna lie, I feel like braindead right now, I have this list now. How should I proceed to be clear, I do not want lists that consist Wall; ModelCurve elements, only DetailCurve and Wall lists.
From there use element Category and filtter out the unwanted category to be left with only the dimension attach to say Detail Curve
Thank you so much!
Thank you so much for your help!
