Thank you for your help. I have removed " in both string now still it is not filtering elemnt by parameter value. I may need bit more help from you. Thanks in advance
Well, it’s hard to say is it filtering correctly or not. You need to pin results for Element.Getparameterbyname, String.Contains and Filterbyboolmaks nodes and send one more screenshot.
Also, I see you’re using OUT list from Filterbyboolmask, which may be the culprit. Try using IN list
And the last thing - you need to have separate Active view node to connect in to View input in Create tag node.
