I’m trying to find out if the first few characters match some rules.
0 is a letter
1 is a number
2 is a .
3 is a letter
Currently I’m doing this like below but I was wondering if there is a more efficient way?
0 is a letter
1 is a number
2 is a .
3 is a letter
Not sure if it’s more efficient, but it might be a bit cleaner. Does require performing 63 equality tests for each string you feed it, but 63*47 isn’t going to break the bank from a run speed standpoint. I certainly wouldn’t do this for more then single character tests as shown here, but I found that it worked in 23 milliseconds for 220 4 digit strings. Results may vary, and I may be missing a case or two, but I don’t have a real data set to test it on at the moment.
Regex to the rescue:
Python:
# Import RE (Regex) module
import re
data = IN[0] # Input strings
# Alpha, numeric, '.', alpha
check = "[A-Z][0-9][\.][A-Z]" # RE Search string
OUT = []
for d in data:
if re.search(check, d):
OUT.append(True)
OUT.append(False)
I haven’t used the regex node you are using but you could try using this as the regex input:
[A-Z][0-9][\.][A-Z]
as a string
