Is it possible to filter linked walls by workset? All the exterior walls are on the same workset inside the linked model.
I am trying to filter down to all exterior walls, separate the walls by type, and calculate the areas of them.
So far:
So far:
It looks like you’re using GetParameterValue on the parameter list itself. You need to use it on the wall element.
