Hey
I want to filter all views in Revit on the views discipline, but am struggling with the following error code:
What am I doing wrong?
Hey
I think you’re using the BoolMask node incorrectly. Can you show your node previews? The mask
input should be a list of true/false values to filter the list
input.
I don’t think you understand what a “bool” is… A bool is either a “true” or a “false” value…
The “mask”-boolmask would thus be a list of true/false values with the same length as your “list”-input - list.
I understand what a bool is. How I understand a boolmask works is that it checks whether a condition is true. When its true then it will fill the IN part of the node…otherwise it will fill the OUT part.
My new approuch …with no succes so far
You’re searching for a number. You need to use "2"
in your code block so it’s formatted as a sting.
Thanks its working now
Ok…I see that I didn’t understand the mask part…hopefully won’t make the same mistake in the future and waste your precious time
No problem We all start somewhere and the only way of getting better is to keep at it and make mistakes! Keep it up!
