I have standard values, for example, when it sees 300-1000 input, I want its output to give me the values in the code block. Is it possible to do this in python or code block?
If 300-1000KG ROCK
represents a range of values you can use a nested conditional statement. If that’s a static value you could also use a dictionary. Both are possible in DesignScript or Python.
These are actually a workset name. I have a special number parameter in my project and I want to print those parameters accordingly.
