I want to filter out some elements of my model. All of my elements (Floors, Columns, walls, etc.) have an Typeparameter called ‘cpiFitMatchKey’.
Now I want to filter all elements wich Parameter cpiFitMatchKey is for exaple ‘Test’.
@Gregor_Warneke, do you have a graph started we can discuss? It usually helps if you can take a stab at it and the Forum can help if you get stuck.
I would say that you should get All Elements of Category for those elements, then Get Element Parameter for the parameters you mention and check for the value.
@SeanP: Here ist the graph. It has two lines. The upper one gives me all instance parameters. This line works for all Revit types .
The lower line gives me all Typeparameter but only for the Floor Types. I want the lower line works also for all Revit Categories.
hi @Gregor_Warneke, this UI node can collect and select elements based on a parameter and its value.
Unfortunately, can only collect a single category at a time. Anyway, if you want to give a try, this node available in Quasar Package.
