I want to fill “Wall Finish” ;“Floor Finish”; and “Celling Finish” parameters selecting some rooms by name… dor example i select all bedrooms and say they have a woof floor finish. these are instance parameters, I can´t watch the parameter value… i already tried with one room and works but with more do not work… can you help me plz?
Thanks for you sugestion but do not work…
What happens when you do that?
I Can sort them by name but when i want see “Wall Finish” Parameter from the sorted rooms they do not show…
It is like he do not read the “wall finish” like a room parameter…
But if i do this with only one element he can read like suposed…
You might have some unbounded or unplaced Rooms
Please check that and try again if you solved that
I tried with a small project with only 3 rooms, and i deleted unplaced rooms… same problem…
You want to filter the rooms, not the parameter values.
I want to change parameter values from the rooms already filtered…
its like he do not understand the elements from the list i filtered…
Now is working… Thanks a lot for your patient
