FamilyType Parameter Type
Hi!
Is it possible to create FamilyType Parameter with the node Parameter.CreateSharedParameter?
If not how to automate it?
Manually it is a 2 step process:
  1. select Parameter Type
  2. select the category e.i.: Doors
How to achieve the second step in dynamo (ideally by means of interpreting a string imported from an excel sheet)?
Thank you!
familyTypeParamTEST.dyn (5.6 KB)
OK :frowning: Thanks a lot tho!
