Hi! I am trying to insert a bunch of Generic Models (Panels) to fill a “surface”, to do so I am finding the insertion points for the panels on the surface.
What is throwing me off is If I do so In one direction I get a perfect result. But is the other direction (cross direction) Although It returns all the panels the panels are placed almost randomly, not a single one it placed in the specified location.
As you can see the points on the surface are correct and spaced correctly. If I aligned the panels manually everything fits nice.
Any ideas?
That is the code I use to insert the Panels.
from Revit.Elements import *
clr.AddReference('System')
clr.AddReference('RevitAPI')
app = uiapp.Application
dataEnteringNode = IN
symbol = UnwrapElement(IN[0])
refPlane = UnwrapElement(IN[1][0])
location = UnwrapElement(IN[2])
referenceDirection = UnwrapElement(IN[3])
out = []
if type(refPlane) == "List":
refPlane = refPlane[0]
if symbol.IsActive == False:
symbol.Activate()
doc.Regenerate()
reference = Reference(refPlane)
for z in location:
r1=[]
for e in z:
new = doc.Create.NewFamilyInstance(reference,e.ToXyz(),referenceDirection.ToXyz(),symbol)
r1.append(new)
out.append(r1)
OUT = out
Thanks!
