Hey All,
I’m at a loss! I’m creating a routine that will load a new titleblock .rfa file from our network into a model, and then change the type of an inserted titleblock to that newly loaded one.
I’m using some dialog boxes with Data-Shapes, and eventually get to a point where I’m using the “List.Combine” node with the “String.Concat” node as the “combinator”, the “Directory Path” node (within which I chose the folder on the network where the family exists) feeding into “list1”, a “string” node with a “” (backslash) feeding into “list2”, and, as a result of the user selecting one of the families from within that folder using the “UI.MulitpleInputForm ++” node, feeding into “list3”. This creates the directory and file path of the .rfa file I want to load into the model:
L:\REVIT\Libraries\2019 NK Architectural Library\Titleblocks\30x42 - 2018 Logo\NK - NJDCA - Titleblock 30x42 2018.rfa
The “List.Combine” node outputs to the “List.GetItemAtIndex” node’s “list” input, with a “0” feeding into the “index” input. The output of that node feeds into the “Document.LoadFamily” node. When run, however, the “familyTypes” output says “null” and the “success” output says “false”.
I can’t figure out why. Any help would be GREATLY appreciated!
Titleblock_Swap_v01.dyn (119.2 KB)
Thanks,
Scott
