BDDIV-SSH-XX-XX-DY-BI-0150-S0-P78_FamilyTypesMonitorByExcel_ReinardtBronkhorst.dyn (502.2 KB)
I specifically want to handle the case where a user has deleted the last type from a family and then I want to create a new type.
The code fails here:
try:
famDoc.FamilyManager.NewType(xTypeName)
loadOpts = FamilyOption()
oFamily = famDoc.LoadFamily(doc, loadOpts)
except:
pass
The error message is below, and note the script stops without passing values to the other nodes:
Even though the family type is now in the project:
Any help is greatly appreciated
Here is the full code
import sys
clr.AddReference("ProtoGeometry")
import math
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
clr.AddReference("RevitServices") # Import DocumentManager
import traceback
clr.AddReference('RevitAPI') #import clr
from Autodesk.Revit.DB.Plumbing import *
import System
clr.AddReference("DSCoreNodes")
from DSCore import *
class FamilyOption(IFamilyLoadOptions):
def OnFamilyFound(self, familyInUse, overwriteParameterValues):
overwriteParameterValues = False
return True
def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues):
source = FamilySource.Family
overwriteParameterValues = True
return True
xCategoryNames = IN[0]
rCategories = IN[1]
rFamilyCategories = IN[2]
oCategories = IN[3]
xFamilyNames = IN[4]
rFamilyNames = IN[5]
oFamilies = UnwrapElement(IN[6])
xTypeNames = IN[7]
rTypeNames = IN[8]
oFamilyTypes = IN[9]
output = []
for i, (xTypeName, xFamilyName, oFamily, rFamilyName, rCategory, rFamilyCategory) in enumerate(zip(xTypeNames, xFamilyNames, oFamilies, rFamilyNames, rCategories, rFamilyCategories), 0):
if ((rFamilyName == "OK") and (rCategory == "OK") and (rFamilyCategory == "OK")):
bip = BuiltInParameter.ALL_MODEL_FAMILY_NAME
provider = ParameterValueProvider(ElementId(bip))
evaluator = FilterStringEquals();
rule = FilterStringRule(provider, evaluator, xFamilyName, True);
filter = ElementParameterFilter(rule);
pFamilyTypes = FilteredElementCollector(doc).WhereElementIsElementType().WherePasses(filter).ToElements()
if len(pFamilyTypes) > 0:
foundFamilyType = False
for pFamilyType in pFamilyTypes:
parameters = pFamilyType.Parameters
for parameter in parameters:
if parameter.Definition.Name == "Type Name":
if parameter.AsString() == xTypeName:
foundFamilyType = True
oFamilyTypes.append(pFamilyType)
rTypeNames.append("OK")
break
if foundFamilyType == False:
try:
oFamilyTypes.append(pFamilyTypes[0].Duplicate(xTypeName))
except:
oFamilyTypes.append(None)
rTypeNames.append("ERROR EXCEPT - FAILED TO DUPLICATE")
elif len(pFamilyTypes) == 0:
TransactionManager.Instance.ForceCloseTransaction()
famDoc = doc.EditFamily(oFamily)
TransactionManager.Instance.EnsureInTransaction(famDoc)
try:
except:
pass
typelist = list()
output.append(oFamily.GetFamilySymbolIds())
for famtypeid in oFamily.GetFamilySymbolIds():
typelist.append(doc.GetElement(famtypeid).ToDSType(True))
rTypeNames.append("ERROR - SOME FAMILY ISSUE")
OUT = xCategoryNames, rCategories, rFamilyCategories, oCategories, xFamilyNames, rFamilyNames, oFamilies, xTypeNames, rTypeNames, oFamilyTypes, output
