Yep
good to know. thanks for everyone help
In Revit 2018 (I havenāt tested older versions) the rotation of the family is about 0,0, we found this out as some families have had there reference planes (front/back, left/right) have been moved slightly.
To find 0,0 in a family, create a dwg and insert it.
has anyone else found a better workaround for this?
@Kulkul Iāve revisited this and am still having issues.
Attached is the family (revit 2018). It only has 2 reference places. It is (as far as I can tell) identical to your family in terms of reference plane naming and defines origin location.
Stadium_Seat_New.rfa (276 KB)
However when I rotate them using Dynamo, they behave very differently
What is causing this? It must be how the family is built but I canāt figure out what. It is like it is being rotate about the hidden start-up point. Is this possible? Exporting a dwg and re-importing I get overlapping geometry.
@Paul_Wintour Shifted the geometry in the family to the origin (0,0,0)
Should work properly now.
Stadium_Seat_New.rfa (420 KB)
This works but I canāt work out why. How do you find the origin (0,0,0). Isnāt it the ādefines locationā point of the reference planes. If not, there is nothing under visibility graphics so how do you find it?
Determined the origin by Importing (origin - origin) an Autocad file with just a circle at (0,0,0)
Also mentioned above in this discussion ā¦
hmm ok. I exported the file to dwg and re-imported it back it. But that it always overlay the geometry. I need to create the autocad file from scratch I guess.
Use dynamo to draw a model line from 0,0,0 to 10,10,10 in your family environment instead of using a dwg. This was mentioned by @Johannes_Meiners above (I think linie vom nullpunkt means line from zero point), but he draws his to 0,0,100 instead.
thanks. It would be so much easier is there was just a family base point under visibility graphics. Not sure why they canāt implement that. It seems pretty easy and quite critical
Draw a āxā at 0,0 on autocad. Then insert the drawing
Which archi lab package is to be downloaded. There are so many.
There are many by necessity - get the latest, and if that doesnāt work get the latest version based on product year (so Revit 2018 try 2020.22.7, if that fails or acts up then 2018.13.13).
