Is there a node that creates a Family instance By Line In View.
I have found Family Instance By Point In View (Does not take line data) and Family Instance By Line (takes level not view). Neither work for my case.
Any help on creating a node that does would be great
What the Node is returning null when I search for the Geometery.toRevittype
Can you point me in the right direction
Whoops , I must not have documented that one. That is in Rhythm.
John I thought that i modified everything correctly to fit my needs, but I am getting an error in the python script. Can you take a look.
Fire Rating Script-modified.dyn (46.4 KB)
What error are you receiving?
Warning;
IronPythonEvaluator.EvaluateIronPythonScript operation failed.
File “<string”, line 24, in <module
AttributeError: ‘List[object]’ object has no attribute ’ IsActive’
Kulkul
April 4, 2017, 5:38pm
9
@dpohlman Could you show us graph image?
Posted here
Revit Forum
This page is not visible. Can you explain the solution?
