I just gave your code a go. Good news is that it works, bad news is I’m not sure why it doesn’t work for you… I tried with Revit 2017 and dynamo 1.2.1:
Hi Kulkul,
I’m using the @Mostafa_El_Ayoubi code without results. (the @erfajo code gave me an error)
with reference to mostafa code, a “false” appear in the OUT watch. NO changes have been applied to the families stored in the called folder (read only flag has been removed).
The shared parameter file is also attached. SP.txt (810 Bytes)
@fablabolbia
you need to feed the right data from your Shared Parameter file. I have no idea what “Group 3” and “Group 1” is, these “items” is not a part of the SP file you have uploaded.
And… please try to see this post, use the nodes in DanEDU Dynamo package instead.
i’m having pretty much same issues with it crashing… not sure if it’s because of the same problem as you fablobolbia but i would really appreciate if you could update once you find a solution as i’ve tried to search so much for one that i got headaches and had to take drugs for them, i can’t search further anymore. Mostafa also thanks for answering that guy’s questions. you seem to have some good knowledge… would you mind if i am going to have some questions either? thanks!
At the moment I can not find a solution…I’m not sure if I’m a stupid or if there’s no real working code in the forum but just “suggestions” for people (not me ) with higher programming skills…
