Hello guys,
I would like to run an external command from RoomBook. I found the command in journals:
CustomCtrl_%CustomCtrl_%Quantification%Areabook Extension%Calculate Areas:Adsk.DrxApplication.DrxAreaCalculationCmd
when I use RevitCommandId.LookupCommandId("CustomCtrl_%CustomCtrl_%Quantification%Areabook Extension%Calculate Areas")
it opens the window but I can’t make it happen to click on “Calculate”
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
clr.AddReference("RevitAPI","RevitAPIUI","RevitServices")
uidoc = DocumentManager.Instance.CurrentUIDocument
uiapp = uidoc.Application
commandName = r"CustomCtrl_%CustomCtrl_%Quantification%Areabook Extension%Calculate Areas"
calculate = ""
test = RevitCommandId.LookupCommandId(commandName)
uiapp.PostCommand(test)
