I wanted to share this quick graph that enables you to export PDF’s in Revit 2022. I can’t believe just how easy it is now.
#Sean Page, 2021
clr.AddReference('RevitAPI')
clr.AddReference('System')
Sheets = UnwrapElement(IN[0])
Names = IN[1]
Folder = IN[2]
result = []
sheets = List[ElementId]()
opts = PDFExportOptions()
#This will uses the Sheet Size for Paper size, or default to Letter
opts.PaperFormat = ExportPaperFormat.Default
for sheet,name in zip(Sheets,Names):
opts.FileName = name
Sheet = List[ElementId]()
Sheet.Add(sheet.Id)
result.append(doc.Export(Folder,Sheet,opts))
OUT = result
Export PDF Revit 2022.dyn (11.9 KB)
