Managed to get a export to Excel running successfully using Dynamo. I am now trying to use this tool for exporting pile loads out to Excel, the engineer to change them then push them back into the model.
I’ve created a number of parameters using the structural load parameters. I seem to be experiencing some strange outputs in the excel document I was wondering if someone could tell me why this is happening.
I used the structural force parameters for ‘Pile Load Max Axial’ and used a common number parameter for ‘Pile Load’. The only thing I can think that is causing it is because it is being pushed through a number prior to exporting to Excel.
Hi Thanks for your response ‘Pile Load Max Axial’ is Structural / Force shared parameter. When entered as 10.000kN in Revit when exported to excel it comes out as 32808.4.
