Hello
I’m trying to manipulate the borderlines of a cellrange in excel. Is it possible to alter the bottom borderline only? If it’s not possible with Dynamo could someone help me to get the code for Python.
Hello
Do you know how to use .NET codes in Python?
I could do it but now I don’t have much time…
You should open a workbook and then worksheet and then define range with .NET functions. After that use for example
ActiveSheet.Range(“A7:H7”).Borders = 9
I don’t have experience with that, but it’s great to see that it’s probably possible
I’ll try to figure out what .NET functions are.
import sys
import System
from System import Array
clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c')
from Microsoft.Office.Interop import Excel
System.Threading.Thread.CurrentThread.CurrentCulture = System.Globalization.CultureInfo("en-US")
from System.Runtime.InteropServices import Marshal
excel = Excel.ApplicationClass()
excel.Visible = False
path , c_range = IN
wb = excel.Workbooks.Open(path)
ws = wb.ActiveSheet
wb.ActiveSheet.Range("A7:H7").Borders.Item(Excel.XlBordersIndex.xlEdgeBottom).LineStyle = Excel.XlLineStyle.xlContinuous
excel.ActiveWorkbook.Save()
excel.ActiveWorkbook.Close(True)
Excel.Application.Quit
OUT= "Alles OK"
Thanks for your help!!
I have little experience with Python nodes, so what do I need to make it work.
I’ve created a Python node and replaced the code with your code and assumed that for the IN part a path node was needed.
Is that correct?
Ok I figure that you have to create a custom node, so I did:
What’s the next step?
I had also as input the range so add another input.
c_range and path I added as tuple. You can also add like that:
path = IN[0]
c_range = IN[1]
You can assign the range via INPUT.
Thanks for your great help. It works!!
I want to fead the python code with a list of ranges instead of one range only. What do I need to change on the Python code to make it work?
import sys
import System
path , c_range = IN
ws = wb.ActiveSheet
for rng in c_range:
wb.ActiveSheet.Range(rng).Borders.Item(Excel.XlBordersIndex.xlEdgeBottom).LineStyle = Excel.XlLineStyle.xlContinuous
OUT= "Alles OK"
Great, thanks! … I really need to learn Python.
