Python.org has posted the following. Please note that as far as I know Dynamo versions of python do not ship with the affected libraries. This is for users who have added pip, uv, certifi etc. to be able to install external libraries. Hopefully Autodesk will provide further advice
Information for Python users regarding eMudhra / emSign CA certificate security incident - Announcements - Discussions on Python.org
Of course one for the dynamo team to act accordingly, but when you load python in dynamo it does create a python folder within the app data local folder(%LOCALAPPDATA%). This can then be used to run/install modules from pip by following the below guide, so yes it may not ship with it but may install by other methods.
Customizing Dynamo’s Python 3 installation · DynamoDS/Dynamo Wiki · GitHub
Thanks for flagging this @Mike.Buttery and @Brendan_Cassidy.
I believe Mike is right that the Python bundled with Dynamo doesn’t include certifi or pip out of the box. Brendan’s point is a good one too, though. If you’ve pip-installed anything into that Python environment under %LOCALAPPDATA% (like the Customizing Dynamo’s Python 3 installation guide walks through), I’d follow Python.org’s guidance and update certifi and any related packages in there.
I’m going to confirm with the team and will follow up here if there’s anything official.
