This is a dynamo file created by Jeremy Graham in his website
I need few changes in this script
In my project file I have curved walls and Walls with profile causing issues with running this script.
its getting arc’s as a room finish boundary stops running the script.
It would be great if anyone could modify the python script or filter the list to get views
Sorry for the late reply
The above script creates elevation in front of all the walls of rooms. The python script doesn’t consider the arc shaped walls. So i had to filter out all the arc walls from the list. still I am getting this error after the input. Anyone please help me to the next step.
This is python script used on that node
from Autodesk.DesignScript.Geometry import * #The inputs to this node will be stored as a list in the IN variables.
curveLists = IN[0]
Not sure if it will solve your problem, but try putting a code block with «seq[0]» between your flatten node and your python script. Does it help? What difference does it make?
