Use the bb min to create a plane, pull the curves to that, extrude curve as solid by the bb max and see what’s inside it…
I had a go here but with areas… Get elements inside an area
The complexity was things like walls which are partly inside (and have a line for a location) so it depends if you want those or not.
Hope that helps,
Mark
