i need to use an additional node Element. element.getrotation.
i have problem to sync with server. is there another way i can download the package? tks
You need to update your software to get up to date with tls requirements.
All updates can be found by navigating from this page: Transport Layer Security (TLS): Updates Required to Maintain Software Access
But likely you just need Revit updates for your active Revit versions, a list of which can be found here: Autodesk Transport Layer Security Updates Require Revit Security Fix
