Hi Guys,
I’ve managed to filter a large number of pipes down to their individual system with help from the forum! In the process, it appears that I have now ended up with a list of strings not elements (I think).
What I need to do is to convert this list back to a list of pipes so that I can feed them into another dynamo graph where I would normally be using: Elements>All Elements of Category. Is it straight forward to get this list back to a list of elements?
I’ve searched through the nodes and can’t seem to find anything
See below:
Thanks for any help
Trying to do something like this! (Join two graphs together)
Here’s the graph if it helps
Pipe by System - Change Pipe Type.dyn (20.5 KB)
Thanks.
As I pointed out in the other thread, by feeding the results of the Element.GetParameterValueByName you are now filtering a list of parameter values instead of elements. Use the node feeding into the get parameter node as your list and you should be fine.
Hi Jacob,
Thanks, I tried this but it didn’t filter the list down. It returned all 200 pipes. Am I doing something wrong here?
Apologies if I am misunderstanding, still learning!
Paul
Apologies, you were spot on!
It was the list level in the list.FilterByBoolMask wasn’t set correctly!
Thanks again for all your help.
