What is this warning? Im trying to create faces from doors.
Show complete graph with all the previews on and errors expanded. It will help others to understand your issue.
what does the error says at Element.Solid?
Warning: Element.get_Solids operation failed.
trim_with_edge_loops requires all curves to touch surface
Its only when the category is doors. When its windows there is no error.
why do you need solids? What is your end goal.
Actually I need surfaces. To get the area and perimeter of each window and door.
@moeng Why don’t you
sort windows/door by type
Count how many instances of each type
Get the parameters width and height . Do some math.
That was my first thought. But the windows and doors are not always rectangular.
So if I get the surfaces I could get the right area and parameter.
