Dyno Ribbon Button Descriptions
Would anyone know how to control what text is being shown when you hover over a button in your dyno ribbon?
dyno description
At the moment, it just repeats the name of the dynamo script. Ideally, I would want to create a short description for each button to provide a bit of info to users.
Yep. You can do that. See here under Script Tuning Parameters. The desc input node is what you want.
Just create a string node and rename it to β€œdesc.” Make sure to set the node to be an input.
Thank you for that, works perfectly.
