As far as the exe it got installed but is not showing up on the library
There is no need for dyf files.
Can you take a screenshot of the Dynamo packages directory? Thanks
I noticed there are two DynaShape folder. Can you try deleting the one without the underscore?
did that too but doesnāt work but, I copied the packages to dynamo 2.0 folder and it works with dyanmo 2.0
also as reported by few people here I have this issue tooā¦
The issue with the node Utilities.RectangularGrid is that, on some computers, the default value for the input ācsā does not work correctly (and I still have not figured out why as I have not been able to reproduce this error on my own computer)
A simple way to fix is to feed an actual a coordinate system to this input
This will probably also fixes the error with the Solver.Execute node.
Let me know how it goes
Also I just updated the installer to version 0.5.0.74. Please try that as well if the problem still persists
Hi @LongNguyen, Thank you so much for your help.
Initially it seemed to work and the problem with āUtilities.RectangularGridā is resolved but solver is still showing me an error,Since i havenāt worked with dynashape earlier I am not even able to guess why this error pops up
Do you have any solution? Already tried uninstall an reinstall thrice.
Thanks.
Thatās strange. This type of issue should have already been addressed in the latest version.
Can you confirm which version of DynaShape you are running?
Also, it probably still works even with this error (try setting reset to āFalseā and āExecuteā to true to see if the geometies in the background start moving)
Thank you so much , the error still shows up but ,geometry worked as you mentioned ā¦!
thank againā¦!
Only thing that keep me still worried is how Am I going to export the final geometry if it shows such errorā¦?
Ohā¦! forgot this Iam using DynaShapeSetup_0.5.0.63
Thanks. I am still trying to hunt down the cause of the error.
But as far as I can tell it wont cause any real problem, just the annoying warning message
You can still produce real Dynamo geometries for further use downstream. Just pause the solver (set āexecuteā to False) and set āfastDisplayā to False
BTW, the latest version is 0.5.0.74. This should fix the null pointer problem above (at least on the computers that I have tested on)
This file btw is a downloaded sample
Short answer: feed a WorldXY coordinate system into the input ācsā of the node Utilities.RectangularGrid
For more explanation see post 106 above
Amazing Job ā¦ speechless - Where can I can find the AuxeticRotatingSquare file ? Canāt find it on the examples, maybe it wasnāt providedā¦
That file is included in the latest example set. It is in the first post.
I still have an error on that oneā¦ notice that I tried to change my user name manually but that didnāt workā¦
