We want to deploy a custom folder within the attribute however
it does NOT recognize the %userprofile% environment variable.
If we want to do this company wide we need to use %userprofile% for deployment.
Is there another way around this?
Hi @Yab,
Could you host this information in a common folder outside the user profile such as C:\Program Data?
You can expand %userprofile% (i.e. home directory) with python 3 like this
from pathlib import Path
# Path("~").expanduser()
OUT = Path.home()
or for IronPython 2 (and python 3 if you have to use %userprofile%)
import os
# os.path.expanduser("~")
# os.environ["userprofile"]
OUT = os.path.expandvars("%userprofile%")
@Yab did you find a solution to this?
We are loading packages from our server location (I know, bad) to which only a few have write access. I want the config to set the default package download path to a different folder, as you noticed %userprofile% won’t work in the xml file.
