Dynamo Script
Hello everyone,
I am looking to build a curtain wall based on the DWG file. is it possible? if so can someone refer me to a specific guide? I am really new to Dynamo
Likely? Perhaps?
The specific answer will depend on the specific question. To get either you will need to attempt to resolve your issue. Give it a try on your own and provide the specifics to reproduce your work in a follow up if you get stuck.
It’s also best to not try and eat the whole elephant in one run. Start with some simple education in the topic. Do the Dynamo Primer in its entirety (seriously skip nothing - the outcome of placing solar panels isn’t the important bit but the methods to do so are), then try building a simple graph, and eventually build up to the specific skill to create your curtain walls.
