Hello everyone !
Can Dynamo change a project parameter for a list then print to pdf and export to cad ?
I have this project where I have 30 almost identical homes, and I want 30 packages each with the correct plot number (project parameter) show in the tile block.
I don’t think you can do the printing and exporting with the standard nodes. You’ll need to access the API through python to do it.
Do you have any links or sources related to printing ?
thanks
These will give you a starting point:
http://revitapisearch.com/html/1ea1e825-8044-7a27-d9b9-ca463443c3b9.htm
Tho from the sound of it, if you just want to change a parameter in the title block, it might be easier to edit the PDFs in some PDF editor. Revit’s printing is too slow.
