# Dynamo Player Gives Run Complete with Error But Full Dynamo Run Gives No Errors
**URL:** <https://forum.dynamobim.com/t/dynamo-player-gives-run-complete-with-error-but-full-dynamo-run-gives-no-errors/66050>\
**Category:** Revit\
**Tags:** dynamo, dynamoplayer\
**Created:** [July 12, 2021, 1:45am UTC](https://forum.dynamobim.com/t/dynamo-player-gives-run-complete-with-error-but-full-dynamo-run-gives-no-errors/66050 "2021-07-12T01:45:51Z")\
**Showing post:** 2
**Author:** ![Ewan\_Opie](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/ewan_opie/32/77070_2.png) [@Ewan\_Opie](https://forum.dynamobim.com/u/Ewan_Opie)\
**Post date:** [July 12, 2021, 1:58am UTC](https://forum.dynamobim.com/t/dynamo-player-gives-run-complete-with-error-but-full-dynamo-run-gives-no-errors/66050/2 "2021-07-12T01:58:51Z")
Does it perform its function in both instances? If so, the Geometry Working range is a likely issue.
See this comprehensive reply from @jacob.small
> [@Curve.SolidIntersection Error](https://forum.dynamobim.com/t/curve-solidintersection-error/39169/8):
> Can you provide a data set to illustrate this? In theory when using feet medium scale should be able to accurately represent objects as small as a fraction of the thickness of a piece of paper as long as they are within a distance that is 1/3 the depth of the Marianas Trench from the origin. Confirming the upper limit for geometry scaling is actually fairly easy. Find the minimum and maximum point for the bounding box for all elements, and create a vector from the origin to each of those poin…
_[View the full topic](https://forum.dynamobim.com/t/dynamo-player-gives-run-complete-with-error-but-full-dynamo-run-gives-no-errors/66050)._
