Try Element.SetParameterByName Fixer from Synthesize
is this the preview results you asked for?
i have downloaded synthesize but cannot find that you mention?
I have changed from out to in as you suggested. This removed the errors however the coordinates still do not generate. I dont want to use centroid as this script is used for x and y coordinates for piles and also the cut off top level of the pile. Is there anyway i can send either of you trying to help my script to have a look at?
i am trying to update the NumberToString as that seems to be the one that isnt working?
When i go to edit this node, do i replace the number to string with string from object? i am trying your solution but struggling so far
results when i do replace it. It is now creating coordinates but not the correct ones, see revit table and pile plan
the output coordinates are totally wrong, they dont match the survey, project and internal origin coordinates
thats the results from the 2024 version which works perfectly fine. so its def something up with that Convert from Internal Origin Coordinate System node
